Unless you want a project, walk away from it. This thing sounds like it may be a hack job.
What kind of lift is it? If it is a body lift don't buy it. Body lifts are nightmares that you do not want to deal with. Over time the body mounts collapse under the stress and your cab no longer sits right on the frame. I figure it is because I don't see how a suspension lift causes any of these issues.
There is no shift cable. The transmission is electronic with a mechanical linkage that goes from the lever to the trans. They probably didn't bother to adjust anything for the body lift. If this detail was over looked, then there is no telling what other short cuts were taken.
