I'm thinking about trying to get an Amsoil Bypass Filter system to put in my 95 w/ 5SFE. I was looking at a single-filter setup that tee's off the oil press sensor and drops the oil back in at the oil cap. I'd like to do the dual filter relocation so I can use a larger filter than the little bitty factory thing. I just can't find room anywhere. I'll be lucky if I can stuff a single-unit under the battery tray where I was thinking. I don't know where else there is room?
That is, if I can find $180 >.< lol
What with the gear driving the counter-shaft and cam, how long could I likely push a by-pass equipped oil change? 10k? You can do 10k with a 7.3L Powerstroke, which gear-drives the cam off the crank and uses 3000+PSI to drive the injectors.
Thoughts?
Thoughts?
