I recently bought a 1992 Toyota Camry which has some sort factory security system installed... i've read it's probably fujitsu.
I don't have the remote for the car, which is apparently needed to activate/deactivate and program the alarm system. If I enter the car without turning it on.. or even just open and close a door the alarm goes off... this is very annoying. i took a look at the unit which is under the driver's side seat and it has what looks to be a reset button, and a 15/30 second switch. switching it to 30 seconds gives me a bit more time but still does not solve the problem.
also, i read that you can activate "valet" mode by turning the key to ACC and holding down the valet switch located next to the parking brake... supposedly in valet mode the alarm is deactivated. I did this and it does NOT appear to work. also, the led on that switch is broken so there's no telling if the switch itself even works.
If I unplug the unit altogether then obviously the car won't turn on and all sorts of things cease to work.
What I'd REALLY love to do is remove & bypass the thing altogether. can anoyone help me with this? I'm guessing that if i knew which wires to twist together that i could get everything to work without this annoying and presumably broken alarm system.
I've searched everywhere for a wiring schematic for the security system with no luck. please somebody help!
thanks
billy
thanks
billy
