exactly...... the tires...It probably is your tires' increase in noise as it is being worn down.
Again, tires are a likely culprit - there are some combinations of tire, chassis, and pavement that 'sing'. If the noise increase is coincident with a tire swap, then the tires are the most likely suspect. Now, it could be that on some pavement surfaces the tires are OK - but if the noise level is unacceptable over the surfaces you drive on, talk to the place you bought the tires from for alternatives.But Tires are (Michelin Destiny) which I just had it installed last week.
