1998 Rav4, manual transmission, 2WD, JDM engine installed in 2013
Short Answer
I think the lower drawing actually shows two VSVs having different functions: The VSV for fuel pressure control (required on California emissions) and the EGR VSV.
To replace the EGR VSV, I would buy the Aisin VST-026.
Long Answer
The service manual (EG section) has drawings of the EGR VSV and Fuel Pressure Control VSV, mounted right next to each other. In my next post, I linked a site that has the service manual sections.
For the EGR VSV, I see on toyodiy.com the following for a 1995 2.2L Camry (drawing 17-08):
25860 VALVE ASSY, VACUUM SWITCHING, NO.1
25860-74050 NO.1 1 $89.75
25860-74160 CALIFORNIA SPEC 1 $197.57
I googled on the two part numbers and the parts look alike except for color. The Aisin equivalent part numbers are:
Federal, Aisin VST-006 (advertised for both 25860-74050 and 25860-74160)
California, Aisin VST-026 (advertised for only 25860-74160)
As you may know, Aisin is the OEM manufacturer for many Toyota parts.
For 2580-74160, Rockauto's search engine also spewed out both VST-006 and VST-026.
The only difference between the Aisin VST-026 and Aisin VST-006 might be the filter built into the one end? I am not sure.
I will post the EGR VSV vacuum hose routing separately.
Other causes of a rough idle when warm include an iffy ECT sensor; air in the coolant; and a failing front oxygen sensor.
Long Answer
