1 - 8 of 8 Posts
no. no one cares about the camry, even though it's one of the most popular cars on the road.
sorry, maybe next life.
You have two factory options: Upgrade to the larger Camry TRD dual-piston fronts, or the even larger Highlander dual-piston fronts.
Do you have a link on the highlander front brake upgrade? This is something I would like to look into.
Supposedly the Highlander front calipers and rotors are a direct swap. If you have the normal rear parking brake (not the electronic one on the X models) the rears may be a direct swap too. I was given PNs 47750-0e031 and 47730-0e031 for the front calipers.
EDIT: You can't use the Highlander front rotors, they will not fit. You can use the Camry TRD front rotors and the Highlander/RX front calipers, supposedly. I don't know of any upgrade options for the rear, but most of your stopping power is coming from the front brakes anyway.
2018 Camry XSE V6
FYI
Those caliper numbers are for the 2016-19 Highlander (and 2016-20 Sienna). The 2020-21 Highlander front caliper numbers are 47750-0E070 / 47730-0E070.
FYI
I was told the older ones are the ones to use. They came on the Sienna/Highlander and some Lexus RX models. I actually just picked them up this week and will report back with the results when I get around to attempting the install.
Also, I just found out that you cannot use the Highlander rotors, you need to use the Camry TRD rotors. I updated my other comment.
Please do let us know if this is a direct swap. Very interested in doing this. Thanks
1 - 8 of 8 Posts
