1 - 5 of 5 Posts
I want to get this shell that came off a 2000 Tacoma, for my 94 pickup. I measured the length and width of my bed and it is the exact same as the measurements on the one I'm looking at, however, I wanted to make sure it will line up with my cab and be somewhat flush, thanks.
Try to measure the angle of the back of the cab - the back window. There's a big difference between a reg cab & x-cab, for instance.
'93 SR5 PU 4x4
i had one on my 93 ext cab and the canopy was from a tacoma bed. as far as lines go, everything lined up, looked good as far as the bed and lining up with the cab. the only thing that was a little weird was the bed rails must be a little different on the tacoma because the C clamps to hold the canopy on never quite lined up right and clamped at a weird angle. but it was tight on there and i never lost it going down the road.
89 p'up
not really helpful, but S-10 shells won't fit. the bed of an s-10 is wider near the cab than the tailgate, and the roof is higher.
yes, i almost got a fiberglass snug for $30, but it didn't fit :(
post pics when you install yours, ok ?
1 - 5 of 5 Posts
