1 - 4 of 4 Posts
Hi
Camry did today: i turned key and nothing happened, no electric nowhere. I allways switch lights on before start (for cluster lights) and those were also out.
Suddenly electric came back and car worked like nothing. Radio memory was cleaned.
Ignition switch is not my problem then? Battert good and shoes/cables. Is there common main fuse problems or what?
· Super Moderator
Various Toyotas
Did you wiggle your battery terminal leads at the battery?. I had this happen on my '94. The negative cable was loose, mind you terminal connector "looked" fine. I'm not a fan of the original battery terminal ends.
Yeah, sounds like loose or corroded battery terminal connections. I suggest to Karpov that he remove them, inspect, and clean everything up and reinstall to a proper tightness.
1 - 4 of 4 Posts
