1 - 8 of 8 Posts
· ASE Master Technician
2006 Lexus GS430
Does the garage door use a rolling code system? Are you pressing the button on the opener unit itself in the garage to program? You must also first delete any info in the homelink before programming.
Discussion Starter · #3 ·
i don't understand what's the rolling code system?
but i do press the bottom of homelink and my garage opener druing the porcess till end
and i tried delete all info in the homelink, ( press 1 and 3rd bottm to erase)
and process again, but just still can't open the garage by homelink ><
2006 Lexus GS430
Programming Homelink®
Note:​
Some vehicles may require the ignition switch to be turned to the second (or
“accessories”) position for programming and/or operation of Homelink®. It is also
recommended that a new battery be placed in the hand-held transmitter of the device
being programmed to Homelink® for quicker training and accurate transmission of the
radio-frequency signal.
1. Press and hold the two outer Homelink® buttons - releasing only when the indicator
light begins to flash (after 20 seconds).
Do not hold the buttons for longer than 30
seconds and
do not repeat step one to program a second and/or third hand-held
transmitter to the remaining two Homelink® buttons.
2. Position the end of your hand-held transmitter 1–3 inches (5–14 cm) away from the
Homelink® buttons while keeping the indicator light in view.
3. Simultaneously press and hold both the Homelink® and hand-held transmitter
button.
Do not release the buttons until step 4 has been completed.
(Note:​
Some gate operators and garage door openers may require you to replace
this Programming Step 3 with procedures noted in the“Gate Operator and Canadian
Programming” section.)
4. The indicator light will flash slowly and then rapidly after Homelink® successfully
receives the frequency signal from the hand-held transmitter. Release both buttons.
5. Press and hold the just-trained Homelink® button and observe the indicator light.
If the indicator light​
stays on constantly, programming is complete and your
device should activate when the Homelink® button is pressed and released.
Note:​
To program the remaining two Homelink® buttons, begin with “Programming” -
step two​
. Do not repeat step one.
If the indicator light blinks
rapidly for two seconds and then turns to a constant
light, continue with “Programming” - steps 6-8
to complete the programming of a
rolling code equipped device (most commonly a garage door opener).
6. At the garage door opener receiver (motor-head unit) in the garage, locate the “learn”
or “smart” button. This can
usually be found where the hanging antenna wire is
attached to the motor-head unit.
7. Firmly press and release the “learn” or “smart” button. (The name and color of the
button may vary by manufacturer.)
Note:​
There are 30 seconds in which to initiate step eight.
8. Return to the vehicle and firmly
press, hold for two seconds and release the
programmed Homelink® button. Repeat the
“press/hold/release” sequence a
second time, and, depending on the brand of the garage door opener (or other rolling
code equipped device), repeat this sequence a third time to complete the
programming.
Homelink® should now activate your rolling code equipped device.
Reactions: PEGera
2006 Lexus GS430
Hope that helps, read it over a couple of times and give it a try once you fully understand.
2006 Lexus GS430
I'm Glad i got to you before Njerald, He would have sighed and said to read your manual or search. But I like to actually help.
· Camry SE V6 Navi
push the button on the actual garage door opener (on the ceiling)... then you have 30 seconds to push the homelink button in the car... push it 2-3 times and it should work. I programmed my garage at my place and my parents garage for my car. On mine, I only had to push it twice... at my parents I had to push it three times.
Try that and see if taht works.
1 - 8 of 8 Posts
