Hello,
I have now a problem with my installation I have to completely start over with the system v6. 1992 to take mounts
My question is about changing the mount back at the ink is positioning axle, I change the bearing of place? Then I can use the suport of v6 before gte on 3s without changing?
Thanks
i was just looking at the thread featuring his car! I remember this dude! He came here when Mox took pics of his car, that green 3sgte coupe. Shit i just downloaded the pics! :lol:
Hello,
Yes it is me who has not been very courteous in an old tread I apologize I had a lot of misery in a discussion of English that I am not bilingual I have misunderstood some interpreted that I had received post, then I I have not been very polite, well ...
Now I want to start something new, trying to better reflect not to mislead
that's all well and good. We just can't really understand the first post in this thread. We can't help you without a better translation. If you could clarify the first post we'd be glad to help.
Presentement my situation,
My camry famous green body work is very large project of body!
I was running my facility with my original support system (5sfe) of a lot of breakage (transmission)
I have reinstalled my engine with the media adéquois, by the Board of mox, I buy a manual 1992 camry v6
My problem now
My problem now, I want to see the changes clear that I do support at the rear (moving the shaft bearing?)
I can use the front support v6 engine on the 3sgte without changing?
I am really determined to install the engine so that there remains till death lol
I think he is trying to ask weather the engine mounts on a V6 camry will line up with a 3sgte engine and wether he can use the drive-axle bearing mount from the V6 on the 3sgte.
my cousin help my for traduction,... Hello again ,
My question is regarding the engine support front and back , my installation was with the original (5sfe) support now due to many breaks of transmission I bought a camry v6 92 standard shift to use the transmission support. I would like to know if I can use the front support v6 on the 3sgte without modifying anything . I would also like to know the procedure to follow to install the rear support ,must I change the axle shaft or move the bearing ? I need clear details cause I would like to install the engine for the last time!
I also need some advice concerning my engine due to breakage 3 times I damaged the area where I screw the rear support …I have a couple of pictures I would like to know if I haftoo change the block or if its salvageable !?!
you know what's funny. i looked at the thread from when this car was first discovered and you guys suck. it's a modified camry and the guy put it together with aparently little funds. i give this guy props on his swap cause he did it and it's not common. it doesn't matter that it isn'tclean and shiny geez.
i wish i can help on this swap but i haven't had the chance to do a 3s swap yet. good luck man
As far as I can tell, he wants to swap the V-6 tranny into his 3SGTE coupe and needs to know whats involved.
Basically the same as a V-6 tranny to 5SFE I should think. Owing to Toyota's handy little family-cross-compatibility. (i.e. "S" family engines should all be near-drop in to each other, "A" family, "JZ" family.... etc)
I actually wouldn't mind knowing this either... My 5SFE tranny is a little clunky and doesn't like my 2nd-5th or 3rd-5th shifts. What? Getting to 60mph in 2nd then popping to 5th! lol... I'm not nice to my cars...
