Does anyone have a list of error codes for the camry. It is a 1997 and I am currently getting code 1133, which isn't in the list of codes that came with my error code scanner.
Check your list again, but this time check under P0133. It should be an o2s code of some sort. But don't translate that as a signal for you to go change a sensor, bec. that's not always the case.
