Tonight my neighbor pulled out of her driveway and got about a block down the road before her car started to smoke.
She got out and turned it off, but it only got worse... we stayed away from it and called a fire truck... by the time they got there it there was a ton of black smoke and a lot of fire under the car...
It's a total write-off.
It seems weird that this would just happen for no reason...
Has anyone heard of a fire hazard recall, or anything like this happening?
She has a 1996 Toyota Camry (not sure if it's the 6cyl or 4cyl).
Honestly, this is why you need a fire extinguisher in your car. Preferably one that can tackle both chemical and electrical fires. It's not just for ricey looks.
Contrary to what you see in the movies, cars *rarely* blow up. Even if the fire reaches the gas tank, you'll just get a neat flame thrower effect. Ask any firefighter. Gasoline is not like C4.
So if the fire is not too hot as to be unbearable, you can still pop the hood and put it out before it gets too bad.
As for what started the fire...hell if I know. Those things don't just burst into flames for no good reason. The cars that are prone to fires are usually the ones that have some nasty defects. The Pontiac Fiero, for instance, had a poorly designed exhaust manifold placement and faulty rod bearings on the earlier models that could cause a fire in the engine bay.
It is possibly that some combustable materials got near something hot (like an exhaust manifold), but that would likely be more as the result of something not being maintained right or fixed wrong, rather than anything on Toyota's part. Toyota even warned GM about the issues with the Fiero, but GM ignored their pleas to do something about it.
Friggin' GM....I swear. Only Ford can manage to build a crappier car.
My Lincoln Mark VII LSC started on fire when I slammed on the brakes which caused me to burst a brake line shooting brake fluid on my header... Freak things happen..
Contrary to what you see in the movies, cars rarely blow up. Even if the fire reaches the gas tank, you'll just get a neat flame thrower effect. Ask any firefighter. Gasoline is not like C4.
I have no idea why the Camry burned. I saw a car get hit from the side. The full gas tank leaked and ran down the gutter. No problem until it reached the local sheriff's flare. The gas hit that flare and flashed in an instant 50 feet in the air. People 1/2 mile away saw it and came to see what happened. Sorry, I'm no help but, I couldn't resist telling that story. Mr. duputy sheriff is still employed!
91's have a recall on their radio because the car can spontaneously burst into flame because of the wiring...I suppose I should get around to taking mine out.
Mine caught fire... I smelled an electrial fire and heard sparking. Next thing I know there's smoke around my feet.
Turns out my clutch had sawed partially thru my amp's 4ga power line and every time I pressed the clutch in it was sparking til it caught the carpet.
- John
How many people have had their camry's catch fire? Mine randomly burst into flames this morning at a stop sign...just trying to see if anyone knew about this. Thanks
Camry's Catch FireHow many people have had their camry's catch fire? Mine randomly burst into flames this morning at a stop sign...just trying to see if anyone knew about this. Thanks
On the topic of spontaniously combusting cars and bad design. You've heard of the Honda CRV (or something) where the oil squirts out from around the oil filter and on to the exhuast manifold. I don't know if they've even figured out why yet.
Sounds like there ma have been some kind of fluid leak and it got hot enough to iginite. If so that is one good reason to keep up with oil leaks and things like that. Exhaust parts get hot and can ignite oil based fluids. Which is almost every fluid in the car.
WOW my boy has 93ceile with 5sfe it caught fire at the fire wall next to the fuel regulator guess it was leaking or something but we stoped the flam befor it fuck fucked up the harness to bad .
Well, I guess no one knows the answer to this problem. My 1999 Camry 4cycl. just caught fire this weekend and it appears the fire started at the starter (maybe the starter itself) and now nothing electrical works.
A couple days ago I was driving down the road and saw a late-model Camry pulled over to the side of the interstate with the whole front end on fire, it was obviously going to be totalled. No idea what the story was.
'91's and back had a problem in the doors. Think it was the electric door locks. Believe they changed the logic so power was normally off instead of on in the '92's. And mid-90's Corolla's had an unused connector under the driver's carpet which could short due to snow/slush from driver's shoes soaking carpet. Don't know of any other common problems.
The fire probably burned some (or many) of your wires. Just hope and pray that the computer wasn't damaged :bowdown:
Another area to inspect is the fuse boxes in the engine (near the battery). If you find out what caused the blaze, let me know... since I have a 1999 Camry 4 cyl!
-Joel
Related Threads
Ask a question
Ask a question
Toyota Nation Forum
6.2M posts
587K members
Since 2001
