1 - 8 of 8 Posts
W
Guest
Does anyone know if the moonroof of a 2006 Camry has UVA and UVB Sun
protection? The dealers here didn't know for sure. They said it was "dark"
but "dark" doesn't block UVA & UVB.
Thanks All
W
Guest
Discussion Starter #2
"st-bum" <[email protected]> wrote in news:1137718126.656687.272540
@g14g2000cwa.googlegroups.com:
> I thought all windows blocked ultra violet light. You can't get a
> suntan sitting in a car, AFAIK.
> Or is that not exactly what UVA and UVB are?
UVA & UVB are the harmful rays that can cause cancer. I may be wrong but I
thought you can still get a suntan and even a sunburn without UV rays.
K
Guest
UV doesn't pass through glass.
R
Guest
"Knotty" <[email protected]> wrote in message
news:[email protected]
Wrong! UVA passes through regular glass quite nicely as does IR. Plastics
like polycarbonate on the other hand block below 400 nm
W
Guest
"Ron Jones" <[email protected]> wrote in
news:[email protected]:
> Plastics like polycarbonate on the other hand block below 400 nm
That is correct! UV sails through glass unless you have a special UV
protection on the glass. Even dark sunglass don't block UV unless you
have the coating. My initial question was wondering if the moonroof glass
has that coating and protection?
Thanks
R
Guest
Discussion Starter #6
"Wayne" <[email protected]> wrote in message
> Thanks
If the glass or marketing material does not specifically say that the glass
will block UV, then it probably does not. If it did block UV, you can bet
that the marketing people and the glass would take advantage of the UV
blocking ability. The glass will have marking on one of the corners.
Ray O
J
Guest
Discussion Starter #7
The roof will have the SAME UV protection as offered by the windows.
> Thanks All
J
Guest
Discussion Starter #8
WHATEVER. The window in the roof will have the SAME UV protection as the
rest of the windows.
1 - 8 of 8 Posts
