Last night, driving down Yonge St. after Leafs Victory, my Camry's check engine light came on and the overheating gauge was all the way at the top. Veryyyyy wierd, so I stopped the car and rested it but much later I tried turning it on and it would start, it would turn on then automatically shut off, the only way to get it started was to hit the gas.
The problem with the overheating had never happened but the other problem where the car wouldnt start has happened in the past. I was thinking it could be that not enough fuel is getting to the engine, hence when i slam the gas it starts up, but apprantly my fuel filter was changed recently and no fuel injector cleaner is needed. Next, I thought spark plugs but again, changed recently. What could be the problem? And should I change my antifreeze coolant?
Thanks Guy.
Thanks Guy.
