1 - 3 of 3 Posts
Hello everyone, i have a camry se and wanted to replace the dome lights but i can only remove the plastic cover for the front middle one, but not the 2 on the sides in the front or the 2 in the back. so could someone that knows how to remove those covers can u tell me
and if someone knows how to remove the lights on the doors can u tell me how to do that as well.
The courtesy lights?
Take a strong flat object (Flat-headed screw driver may work) and start on the top. Push in and bend downwards. It should pop off. After that, take out the light, unhook the connector, and you have it.
okay ill try that but do u no how to take the ones in the back seat off cause that is very different like the lights on a plane.
1 - 3 of 3 Posts
