Camry V6 2007 - Slipping transmission
11590 Views 11 Replies 7 Participants Last post by  mcdusty61
Hello i recently buy a used V6 Camry 2007 with 182.000 miles i dont have any record of previous services but i have this problem when the car is cold and i go at slow speed.
Look at the videos.
https://vimeo.com/184617441
https://vimeo.com/184617744
My VIN is this. JA3AY11A62U057906
I will try to change the transmission oil , also sorry for my bad english im learning english here in florida.
Take care guys.
1 - 12 of 12 Posts
That is odd, I have not experienced it but it might be the transmission "flare" issue that seems to be a known problem on some cars. However itwould be worth replacing the trans oil and filter and making sure the fluid level is not low. The problem you are seeing can be caused by a low fluid level
http://www.sonnax.com/parts/3502-zip-kit
Normal for older 6-speed's to have a cold shift flare... usually only occurs 'once'. It took a couple years for Toyota to figure it out.
Pull pan, clean magnets, install ZIPKIT, change filter, inspect old fluid/filter for metal debris, refill with fresh WS equivalent ATF, and keep driving. If any metal debris(especially non magnetic aluminum), you'll eventually need a new transmission.
Reactions: 1
While different transmission then what I have, I have a similar issue with my 2004 V6. Think reading up on it was called a 'transmission flare' and it does the same exact thing - although for me is random throughout driving doesn't matter if hot or cold (Fluid drain refills done multiple occasions, no change).
As mention above, might want to drain and refill the fluid. There is a special method for the V6 2GR method (along with the 2AR 2010+ I4) as there is no dip stick and drain bolt anymore on these transmissions
The 4 and 5 speed autos used on earlier 4cyl and v6 models can also be zipkitted
http://www.sonnax.com/parts/3048-zip-kit
http://www.sonnax.com/parts/3047-zip-kit
Shift kit for the OP is also available:
http://www.transgo.com/products.php...g&category_id=186&parent_id=45&product_id=274
And for older 4 or 5 speeds:
http://www.transgo.com/products.php...g&category_id=171&parent_id=45&product_id=263
http://www.transgo.com/products.php...g&category_id=151&parent_id=45&product_id=262
Either the ZipKit or Transgo will assist in reducing or preventing the normal known issues with Toyota's 4, 5, and 6 speed automatics.
Reactions: 1
Thanks for yours reply, i will do that this month and i will let u know if it fix it.
Thanks Again.
I have a 03 camry 3.0 4 sp auto. Was told I need a new trans. Pretty pricey. Which of these kits would be appropriate? And can I do this in my back yard?
these kits help with some specific problems. If your trans has worn out friction plates or has sticking valves... these kits will not help. Best thing is to start a new thread (not hijack one) and describe the problem with yours in detail.
Reactions: 1
If you have the 2003 V6, you might have the U140E which wasn't the best from what i've heard
Did you lose your fwd or reverse, or overdrive gears? Might want to create a thread about it.
I do have an older thread on it. Thought I would ask about the kit here tho. I'll continue on that one, but, all gears are there, mainly hard shifting or "crazy" shifting. Hope to continue there.
I bought my 07 v6 camry at 5000 miles. When cold there has always been a slip between 2nd and 3rd. I have always either let the car warm up a little before driving or ease up on the accelerator between the shift. My car now has 250k miles and still does the same thing. I shoulda had it fixed while under warranty but hate going to the dealer.
1 - 12 of 12 Posts
