hey guys having some trouble after replacing timing belt and spark plugs. after putting everything back together car wouldn't start. so i put the old spark plugs in. That didn't do anything. Then i checked timing marks. everything was alligned correctly. I smelled for fuel from the tailpipe and saw it on the spark plugs i replaced. so i know i am getting spark, fuel, air. I am thinking i am not gettting compression. does anyone know if the cams can be 360 degrees off. I ask this because when i initially put the timing belt on, the RH cam was off by three teeth to the right. so instead of going three teeth to the left, i turned the cam all the way back around clockwise. I was wondering if doing this will mess up the timing. The next thing i plan to do is just move the RH cam once again 360 to see if that does anything. Any help will be appreciated.
