1 - 2 of 2 Posts
Hi guys,
I have 94 Camry and its "Check Engine" light has been going on / off from a month. I noticed if I drive it for few hours while AC is on, check engine light goes on. If I keep the AC off for next few days and drive it without AC, check engine light goes off. Its engine does not overheat because indicator stays lower or at half. Any ideas?
Thanks,
Imran
Read the codes. Use the sticky at the top of this forum for instructions. You don't need any special tools, only a paper clip or a piece of wire. It really is pretty easy. Then report back here with the code and someone will be able to help you.
Mike
1 - 2 of 2 Posts
