i am after changing the head gasket on my 94 starlet gt turbo ep82, its nearly back together but not such how to put the cam's bak on properly, there r marks on the reverse of the cams but not sure which 1's to use, any help
Should be the smaller ones, then on the belt cog you should see where it lines up with a notch in the plate behind it by looking through a tiny hole at top of cog.
1 - 2 of 2 Posts
