Hi all,
I am buying tomorrow a used set of aluminum rims but I'm not sure if I will have problem with the bore size (center hole).
I have a 1994 Camry LE, 4cyl., with only 14inch steel rims and want to have aluminum rims now (because I have one set of 15inch summer tires).
I saw a used set of Mazda 626 rim (15inch) forsale:
with the following specs (5x114.3mm / 12x1.5 Lugnut / 59.60mm Bore)
My Camry specs: (5x114.3mm / 12x1.5 Lugnut / 60.06mm Bore)
So the Mazda626 has a slightly smaller bore (59.60mm).
Will this smaller bore too tight for my camry's bore ? (I think slightly BIGGER would be fine, but NOT slightly SMALLER) ?
Thank you so much for your guidance.
