This.Speedo cable. Goes into trans.
Valve from old engine you don't need. Take the thing they connect to out.
Power steering line. You need gts lines.
the silvertop trans has a digital sensor. the AE92 has a cable driven speedo. there should be a sensor with 3 pins on it in the trans. you'll have to undo the bolt next to it and yank it out and put the cable gear end into your transmission from the original AE92 trans. and then the screw on the cable will screw right into it.thank you, but i cant find where the cable goes into, and what are gts lines? i feel stupid with my ignorance, haha
Looks like the power steering pressure line from the pump to the rack
