1 - 7 of 7 Posts
J
Guest
hello i have a toyota townace 1987 petrol it keeps over heating what could
it be thanks
R
Guest
"jellybeansdaddy" <[email protected]> wrote in message
news:[email protected]
> it be thanks
There are many possible causes of over heating.
Make sure there is sufficient coolant in the radiator.
check the quality of the coolant.
check the condition of the radiator.
make sure the cooling fan works properly.
make sure the coolant is circulating
Ray O
D
Guest
>> it be thanks
i.e. Make sure the thermostat is not stuck closed.
D
Guest
>> it be thanks
i.e. Make sure the thermostat is not stuck closed or the water pump is
not malfunctioning.
M
Guest
Discussion Starter #6
The cooling system is not properly dissipating the heat produced by the
engine, WBMG ;)
mike
> it be thanks
P
Discussion Starter #7
> it be thanks
If you overheated the engine, the thermostat needs replacing. The wax
pellet mechanism that operates the thermostat is usually ruined after
only one overheat. Make certain that when you replace it you orientate
the thermostat exactly the way it was, (right side up and sometimes
forward as well). Check the cap operating pressure and fluid level of
coolant overflow container and radiator as well. You may have a blocked
hose from the coolant container to the radiator neck. Check water pump
operation and belt tension.
1 - 7 of 7 Posts
