1 - 12 of 12 Posts
So I'm having an issue with my 2020 Toyota Camry SE. Whenever I open the trunk, it opens super fast and almost shoots up before it stops all the way up. I've included a picture of what seems to be the issue as it seems something isn't connected. I'd like to order a replacement, but if someone could help me with the name or link I would be super appreciative. Thanks in advance !
Hood Motor vehicle Automotive lighting Automotive design Bumper
06 Toyota Camry XLE, 16 Corolla S
There should be an attachment point near where it ends. Well within a probably 4 or 5" radius. It looks like a stud with a ball bearing on the end.
Something like this but you will only see the round part.
Household hardware Auto part Metal Fashion accessory Fastener
As you can see in post #4 above, you need to insert the strut back through the hole in the carpet wall liner, and re-attach it to this stud if possible. Hopefully nothing is actually broken, and it just slipped off.
Thanks for the clarification.
I couldn't tell buy your other pic where it goes without the arrow. Eyes are not that good anymore and your pics won't zoom.
Mr. Roo
Super Moderator
Ah whoops, I meant to be replying back to the first original post! What you said is already perfect, I had nothing to add to it haha. Yeah the picture posted is small
Discussion Starter · #9 ·
So the long strut should reattach there correct? The only issue is I believe both ends are solid so I'm not sure how it would re attach?
Discussion Starter · #11 ·
That is where it should be attached at. Mine is a 2019, but should be the same.. I would think.. View attachment 360988
I think I might be missing that black part at the end of the strut. If you take a look at the picture I attached, it's just the strut with metal at the end and no way to attach to the point where yours is. Any idea what that black part might be called?
Discussion Starter · #12 ·
This is the end that is detached from the trunk mount, somehow.
Deck lid lift support # 64530-06010.
Just found the part and probably going to place the order. The hole at the end is where the screw tightens into right? I have no idea how mine lost its cover on top and is completely bare but I guess it happens.
1 - 12 of 12 Posts
