1987 is Gen 2 my friend
Shhh, you didn't see anything
Hey: Thanks alot Flying Dutchman: I know it may sound easy to you but I just want to make sure I don't miss anything. Do you if the 94 toyota camry is the same as an 87 in regards to the rack and pinion. It sure looks like it. Just curious!
Again! Thanks for the info!
55ikagan
Big thanks
@Phil_Bleach! 55ikagan, this thread should be of some help:
Thread.
Jimnist ended up removing the NS Xmember and the exhaust, but the BGB seems to suggest this isn't necessary. It claims it will come out the driver side.
There are two brackets holding the rack to the body - one bolt & one nut each. Torque is 43ftlb. Torque for the universal joint bolt is 26ftlb. Torque for the tie rod end is 36ftlb.
If you haven't undone a tie rod end before here is what you'll want to do. Raise, support, remove wheel. Remove the cotter pin and hang onto it. Remove the castle nut but then thread it back on a good amount (you want some space between the nut and the knuckle). Now, grab a sledge - I use a five pound - and SMACK the knuckle where the tie rod end goes.
Frank is almost giving a good example here, but don't be Frank, put the nut back on a bit. Also, get your hand out of there. (Not a Camry).
If that makes you nervous you can rent one of these.
Say it with me - don't be Frank, put the nut on.
The tie rod end will pop out of the knuckle, then you can remove the nut and the tie rod end. Repeat for the other side. Go to the store and find a cotter pin that is the same as the one you took off. Buy two. Throw away the old ones. Or buy a kit of cotter pins if you plan on working on your car in the future.
Otherwise its pretty straightforward. I'm not sure how similar the rack setup is on the 94 vs. the 87, but it should be similar enough that its a good reference for the procedure. Just don't expect the bolts to be in the same places. I'll upload a picture from the BGB when I get some more time.
Sure thing on the help! Goodluck
EDIT: One last thing! You might want a special wrench to undo the power steering lines. If its giving you trouble, you'll want to rapidly apply pressure to the wrench to try and loosen it. You could also tighten a tiny bit then try to loosen. If they're not coming just go buy the special wrench, it'll be cheaper than replacing the lines or reflaring them.
You don't need Snap-on.
