1 - 9 of 9 Posts
Proud owner of a 2005 double cab, long bed. Damn BEAUTIFUL truck!
Problem is i skimpped on the stereo and got the cheap-o toyota unit (which sucks by the way). Anyways....I want to install an I-pod interface and have read that I need the unit with the CD changer output to do this.
I have the Toyota brand stock unit (which sucks BTW)....the only buttons on my unit are
seek AM FM1 FM2 DISK SCAN
I'm assuming that I have the unit that does not have the patch for the CD-changer???
Is this correct? and if so.....is there any way to hard wire an I-Pod interface into this Gem of a radio?
Thank you in advance.
KLowe
KLowe
Try this link if this is your case
http://homepage.mac.com/ebones/PhotoAlbum13.html
Discussion Starter · #6 ·
Tigrans...
where did you get your bed cover for you taco? Is that a long bed.
Eveyone else....thanks for the help.
Already took of the face place and looked behing the radio. took about 5 minutes. Way to easy.
Thanks yall
Discussion Starter · #9 ·
Success!
Went to Circuit City and bought the usa spec DF-TOY for 59.00 bucks http://www.circuitcity.com/ssm/USA-...18956/catOid/-15421/rpem/ccd/productDetail.do Cheaper than crutchfield. Took home.
Followed these installation instructions http://homepage.mac.com/ebones/PhotoAlbum13.html
15 minutes later everything perfectly installed.
Ran the wire into the glove box (which is very easy to remove).
For others facing this issue.
I have the very basic stock toyota head unit (no CD changer controls).
The DF-TOY unit plugged in perfectly right out of the box. All needed parts included.
Just used a peice of velcro for the interface unit to be installed behind the radio (BTW...there is a TON of space behind the radio).
I really suck at installing anything....but this job was a cinch.
Thanks for the help yall.
KLowe
1 - 9 of 9 Posts
