When cruising at any speed, if the car seems to have a slight judder, almost like a misfire, could this be a symptom of a damaged/worn CV joint on a front wheel?
Thanks
Thanks
CV joints don't typically get damaged or worn unless the boot is torn allowing the grease to get out. Generally the worn cv will make a clicking or rattling noise on turns or on acceleration in extreme cases. If your hearing no unusual noises it would be unlikely that the cv is causing what your feeling.
