cant find a fuse.
1084 Views 4 Replies 3 Participants Last post by  Tercel GTS
I have a 1994 toyota corolla dx and it wont start,so i looked in the big fuse block under the hood right next to the air filer. I notice a fuse was blown, the fuse was an (ALT 100 A). First of all i dont know how to get the fuse out and second where do ya get these fuses. Thank you :confused:
1 - 5 of 5 Posts
Pull it. Take it into any local auto parts store... and say.... "Hey... I need this fuse fool." Simple as that.
The section it's in should unsnap from the rest of fuseholder then access the screws holding the fuse in. Check the manual, somebody may have had problems and tried to correct with higher amp fuse.
That whole section of(three fuses) pulls off because i tried to pull just the single fuse out ant a piece just broke off. and if so how do you remove the section of three
should be a clip holding it in, slides out bottom of fuse box
1 - 5 of 5 Posts
