1 - 6 of 6 Posts
G
It doesn't use any oil but I have noticed that wnen it sits overnight or a day or so it will blow some smoke out of the exhaust. Car is a 1990 Camry 4cl. With 80k. I have been running it a lot the last 6 weeks, 80 miles each way to work in rush hour, chicago and suburbs.
Is this something that needs to be addressed soon or can it wait till it needs some other minor maintenance? Thanks for the replys.
· Toyota Collector
Very common issue, with age the valve stem seals harden and allow oil to seep past them, so you see a blue smoke on a cold start. The only proper solution is to remove the cylinder head and replace the seals. I find fully synthetic oil does not smoke as much, but can expose marginal seals and gaskets, so beware. There are "no smoke" additives you can put in your engine but I don't find them to be very effective.
· 3s-gte in a Camry?!?
'89 Camry Alltrac
Good Toyota specific mechanics will have the tool to replace the valve stem seals with the head still on the engine.
Its not something that has to be fixed right away, at least...
-Charlie
Reactions: 1 person
I "searched" this same topic ended up here. I have the same think going on with my 1990 Camry 3S-FE with about 80k miles on the engine. It is odd that my (current) daily driven 1988 Camry 3S-FE with 180k miles on it does not have this problem.
I had this problem on my 1990 Tercel with the 3E-E. I didn't take the head off the (engine) block. The Tercel head was not a hemi like the Camry. I don't know if this same technique would work for the 3S-FE in the Camry.
Buy a new set of valve stem seals from an auto parts store. When I did this they came with a little plastic drinking straw like tool that was slid over the valve stem. Once the old seal was removed the tool was slid on the valve steam and the new seal with a little engine oil on it was slid over the valve steam seal and into place. A small socket the same diameter of the seal would fully seal it when pushed on it from the top.
The trick to getting the valve springs and keepers off without the valve falling down into the cylinder is what has to be figured out. Two methods I've heard of, one I've used. The first is using compressed air. Make a tool out of an old spark plug that an air line from a compressor can be attached to or use a leak down tester with the correct spark plug thread. Thread this into the head in place of the spark plug and fill the cylinder with air. This will push up on the valve and hold it in place while the keepers are off. I never trusted this with a cold old engine. I wasn't sure how good it would seal and hold the valve up. One drops and you are SOL and taking the head off new. The other method was to use small rope. I've used about 4' of 1/4" nylon, anything that will fit through the spark plug hole. Remove the spark plug from cylinders 1 and 4, then later 2 and 3. For ease start with cylinder 2 and 3, set the crank position to TDC. Remove the spark plugs from cylinder 2 and 3. Stuff as much rope through the spark plug hole (about 3 feet worth) with a needle nose pliers. Then turn the crank clockwise to as close to 180° as possible. There will be resistance, you can only go so far. This is the idea, the rope is being pushed against the top of the cylinder and the valves. Now when the keepers are removed the valves will not fall into the cylinder. After all this you do the same thing with cylinders 1 and 4, but opposite crank positions. It is a time consuming process stuffing the rope in.
I have never done this on a 3S-FE but have done it twice on a 3E-E and a 3E engine. Worked good both times.
Not sure if I did something wrong with the new valve steams they didn't seem to seal a whole lot better, mostly at first. I'm sure it will take some time for them to seal in?
'89 Camry Alltrac
The '88 might have already had the seals replaced once. I think Toyota revised the seals (don't quote me on that ;)) after a few years. My parents did the valve stem seals on my original 1990 Camry after only a few years (maybe 5 years and 100k miles from new), then it never had to be done again (crashed at 267k miles). The work was done at a Toyota dealer.
-Charlie
Our 87 DX use to do that after about 5 years and then stopped. Still have the car. Never happened again. Maybe its the Mobil1 we've used since new.
1 - 6 of 6 Posts
