94 Toyota Camry Wagon, v6 1MZ-FE engine.
The old timing belt slipped and it was torn up and stopped working. Installed a new one, also replaced the front main seal while I was at it. After putting it all together, it won't start. The engine keeps turning and turning, but won't start.
-The Crank, and both cam gears are pointing at their designated time marks.
-I checked the sparks plugs and watched them spark, so that's working.
-I can hear the fuel pump working.
I don't know what to think.
Also, I can't check the check engine light, I found 2, maybe 3 diagnostic ports!
1. A rectangular one under the hood next to the air intake manifold.
2. A round one under the steering wheel.
and maybe a 3rd one, a trapezoid one inside the driver side compartment, next to some fuses.
Either way, I've read to jump E1 to TE1, then turn the key on, and it should flash the codes.
I've done that with both and I get nothing.
I did jump E1 with TE2 on the 1st one under the hood, and the light just flashes rather rapidly, constantly.
Thanks for your time.
