1 - 4 of 4 Posts
2001 Prius
Hi folks,
Our trusty 2001 Prius won't start.
A multimeter shows about 5.5 V on the Optima battery.
With the ignition key in the "On" position there is a weird noise coming from the relay box in the engine compartment.
Nothing electrical of course works (headlights, horn).
Should I just go ahead and get a replacement battery or do some more investigating?
Battery must be at least 5 years pld - probably longer.
Cheers
Most auto parts shops will test your battery. That will give you an answer. Optimas are good batteries but not a forever battery.
The test is done for now, now try charging it preferably slowly to full and Then test it. If over 3-4 years old in extreme cold or heat operation it probably needs t/be replaced anyway but worth a try. Luck. :cowboy:
Optima redtop batteries really are no better than anything you can get off the shelf - they were bought out several years ago, and the only quality attribute is they can be mounted in any direction.... otherwise, you're buying into a name.
Pull the battery out and try to charge it out of the car - that will tell you:
1) if the battery will take a charge or not
2) if the battery does take a charge, there could be a draw in the car
1 - 4 of 4 Posts
About this Discussion
4 Participants
toyotaspeed90
Toyota Nation Forum
Full Forum Listing
