1 - 5 of 5 Posts
Official Misfit
2006
i think its in the owners manual
I have the spec sheet back at home that I got directly from toyota. If nobody posts the specs on here by Monday, I'll post them up here when I get home. Or you can go to a toyota dealership and they can give you a printout with the specs.
Discussion Starter · #4 ·
Thanks! I look forward to seeing the numbers.
The impression I have gotten is that my truck either has zero camber or slightly positive camber. I can see no reason for any car or truck used on city streets to have positive camber.
Racing on a track is a different story....
Here are the specs for a 2005 PreRunner. Don't know if you have a 4x4 of it the 4x4's are different.
2005 Toyota Tacoma 4x2 PreRunner Double Cab, standard bed w/ 265/70/16 tires
Front left Front Right
-0.2 1.3 Camber -0.2 1.3
1.2 2.7 Caster 1.2 2.7
-0.04 0.13 Tow -0.04 0.13
11.1 12.6 SAI 11.1 12.6
11.0 14.0 Included Angle 11.0 14.0
Front
Cross Camber -0.5 0.5
Cross Caster -0.5 0.5
Total Toe -0.08 0.25
make this a sticky since I could not find this info anywhere on line. :)
edit: i just typed this whole thing out with perfect spaces in it so its easy to read and when it posted it took the spaces out.
1 - 5 of 5 Posts
