1 - 8 of 8 Posts
1990 Corolla Sedan
My right hand wheel bearing, for lack of a better word, keeps shitting itself, it's got a shot wheel alignment, but would that cause it to break in the space of less than 500km/300miles? It's not due to doing skids either lol. Last time it broke I did a wheel alignment but it did the same thing again. Could something be bent or out of whack? Any ideas would be awesome guys.
I'm hoping I just timed the wheel alignment too late last time.
Cheers,
Vince.
1990 Corolla Sedan
Discussion Starter · #2 ·
I actually just looked at both front wheels realitive to each other, one is SERIOUSLY on the piss, new bearing, wheel alignment (same day) should be set.
Full Throttle
1993 Corolla SE Ltd
Cheers,
Vince.
There's a number of things that can cause wheel bearings to prematurely fail. The main ones being improper installation or applying too much or too little grease. A split seal will cause it to wear out prematurely too, but generally not so quickly (unless it's subjected to a lot of rain, dust, dirt etc in that 500km time-frame). Let us know if it happens again once you get your new one installed :thumbsup:
1990 Corolla Sedan
Discussion Starter · #4 ·
I'm pretty sure it's just the alignment. Like, it's reeeeeally not good looking. Oh well, wrecker-sourced hub, put in this weekend, get new alignment on Monday and hope for the best.
P.S, where are you based?
Full Throttle
1993 Corolla SE Ltd
Sounds good :). I'm located in Auckland :cool:
Rotary guy...
89 RX-7 Turbo
I find that most of the time when you get a hub from a wrecker it's already on it's way out...
also a big reason for it failing is improper installation. alignment really shouldn't kill it that fast.
1990 Corolla Sedan
Discussion Starter · #8 ·
Nah, I've put it down to alignment, I'll see if I can get pics of just how bad it actually is... It drives like a mushy banana... I check anything I get from the wreckers, 9/10 times I can score new parts for used prices out of them (I have a mate working there)
1 - 8 of 8 Posts
