Well if you're trying to remove the panel with the cupholders and the whole big piece around the PRND2L plate, its really quite easy. Take a flathead, and from the passenger side of the panel, towards the front of it where it ends, pry it up from the side until it comes loose and then just pull it up until the clips pop out. Keep moving up the panel and popping out clips. Then, open your arm rest, and finish popping them out. You can't take it out without lifting the armrest.
