Hi Guys - I've been wanting to convert the Center High Mounted Stop Light bulb from regular incandescent to LED. The more I see bright LEDs on the newer cars, the more I notice how dim the incandescent is.
Did a quick search and haven't found a clear answer if this can be done on the 2003 Camry.
Thinking of either changing the bulb itself or somehow install a bright led strip in the housing.
SuperbrightLed site shows a possible 921 LED Bulb - 19 SMD LED - Miniature Wedge Retrofit or possible 921 LED Bulb - 15 SMD LED Tower - Miniature Wedge Retrofit. Not sure if it would fit, etc.
Anyone done either or have any suggestions?
Thanks!!!
Thanks!!!
