1 - 16 of 16 Posts
Proud 93 Corolla owner
Corolla 93
hi ya`ll i have a 93 corolla, my problem is that the centre console lights randomly shuts off when it`s supposed to stay on, how can i fix it, any ideas suggestions.
the lights are from the a/c heater control panel, on and off when over a bump or something like it.
any help apreciated, thanks!
Corolla 93
is there a REAL solution?
You asked for it...
That's only one bulb lighting up that entire panel. It's probably just loose or going bad.
You should be able to get to it from underneath that panel. Take off stuff til you can get in there, it's a bit of a pain but take your time and you'll be able to do this, no problem.
Corolla 93
question: hazard lights switch and rear defrost buttons have ligths???
I too am wondering this?
Guess I'll be taking stuff apart when I get the chance!
Corolla 93
Discussion Starter #7
can i put a led in there???
how can i do it?
has anyone done it?
I'm sure you can..
When I get the chance I'll figure it out and post it up
SUBARU LEGACY
lights
yes azcorolla is right . bulbs are probably bad. the filament will come loose and then when you bang or hit a bump it will come back on when the filament touches again. the hazard and defrost buttons do have bulbs in them some are replaceble and some are not the dealer parts dept. can tell you.
Official TN Toaster
2000 Celica GT-S
The hazard and defrost use Neo Wedge bulbs that you can't find anywhere... the dealers just sell the entire switch assembly. Of course, you can find them online, even LED if you want.
Corolla 93
Discussion Starter #12
can the hazard and defrost bulbs be replaced with other type, LED or standard 12v bulb??
Official TN Toaster
2000 Celica GT-S
LEDs should work, but keep in mind the bulb is about 5 mm in diameter so really only the Neo Wedge type bulb you probably won't have much luck.
Hi,
I don't know too much, but maybe it's a fuse? When I purchased my car, all my dash lights were out. Simply take out the instrument panel (it will only take 15 minutes, possibly half hour? - I did it in the auto part store parking lot so it couldn't have taken that long) and unscrew the bulbs and replace them. It sounds like a hard task, but isn't really too much work. Additionally, what work it is pays off since you can see your instrument lights at night! Hopefully this helps!
For LEDs I used the following leds to convert the dash.
http://www.superbrightleds.com/specs/NEO.htm
8 x white neo-3s - radio faceplate
1x white neo-3 - a/c button
1 x white neo-4 - defrost switch
1 x red neo-4 - hazard switch
http://www.superbrightleds.com/specs/74.html
1 x white 74-CWHP3 - HVAC controls
1 x white 74-CWHP3 - ashtray light
http://www.superbrightleds.com/specs/bulb_specs.htm
4 x white WLED-W - guage cluster
1 x white WLED-W - automatic shifter light
http://www.superbrightleds.com/leds.htm
1 x white RL3-W3030 - driver's side power window switch
1 - 16 of 16 Posts
