1 - 16 of 16 Posts
Does anyone have any idea on how to change door handles on my 94 Camry? Any info would be greatly appreciated!!:help:
· Pochacco Owns Me
you'll have to take off the door panel. unhook the 2 the door latch/lock wire. there should be 2 screws holding the handle on, one one each side. and that's it
· TN Pussy Man
Camry
^ what he said..
and your best friend when it comes to diy projects is a haynes manual or a chiltons manual:thumbup:
· Know God. Work Hard.
4Runner
Haynes manual dosn't show you how to do everything :(
· I'm a Mac
DD - 94 Mitsu 3000GT
OKOKOK here it goes... make sure your window is up before doing this.
take off the door panel. first you need to take the trim off around the door handle. you need to get a flat head screw driver in right under the locking mechanism and pop the door handle trim off. same on the top side of the handle's hinge. there should be 2 big screws in the arm rest. 2 screws on the bottom, 2 pins on the side, 1 screw towards the inner side. and one more below the arm rest in the little magazine/map holder spot.
now that you got that off, there should be 2 screws/bolts holding the inner handle in. unscrew those and then remove the metal lines from the mechanism. the plastic things pop off to the side and then the metal pieces will slip right out.
the outer handle is a little tougher. first you have to get those metal lines off, same way. then you have to reach in there and unscrew the 2 screws/bolts in there... the window must be up, and you will have to break through that shitty plastic lining in the door. once you get that off, you can pop the outer handle out the side.
lemme know if you have any problems. i check the forums a few times every hour :) im a big dork like that.
did anyone follow zoni's instructions? i tried it on my 93 cam but i couldn't get the trim around the handle off. and i didn't want to damage the stuff around it with the screwdriver (i think i already made a hole?
1 - 16 of 16 Posts
