Just like normal..when installing new brakes, calipers, new line, etc., what is the procedure for adding new brake fluid? Do I need computer input or just bleed like normal
Driver’s side rear first since it has the longest line.Bleed passenger side rear first, then driver's side rear, then passenger front, then driver front.
If the truck has the traction control magic that was added in '09, it will make bleeding the front brakes easier. The traction control will automatically pump the brake fluid through the front brakes when you turn the key to "ON" and touch the brake.
