: Dunno---why did they move it from under the hood to on the frame when
: they were still carburated 22R's?
An inspired stroke of bad engineering contaminated by Toyota's association with Generally Mediocre (GM)? Why did my Toyota have a
GM "green (but blind) eye" battery in it (which was the first component to fail after only a few month's service)?
: We do agree that the owner's manual recommended intervals are a bit
: long, but if the Toyota has a recommendation of 'never' then even it you
: change at half the recommended interval that's still 'never'.
: > If it's not meant to be regularly replaced, why are there so many aftermarket
: > filters available?????????????????
: Because there are people that are willing to buy them????????????????
Any part that carries the volume of fluid that a fuel filter does is highly prone to failure. Now what exactly does "lifetime"
mean? The life of the vehicle or the life of the filter? The lifetime of a butterfly is grossly different than the life of a
tortoise.....
: > Finally, my dealer (Bell Road Toyota) said to change it by 60,000 miles.
: And I'll bet they wanted to be the ones you hired to do it.
Can't argue there; just like they did when my crap and bunion bushings went bad. Whoops! New $1500 ("remanufactured") rack instead
of $15 worth of bushings. Same when inner tie rods went bad. Whoops! New $1500 ("remanufactured") rack instead of new tie
rods.... Wrong on both counts! Two things I try to avoid in life: more pastries (have you seen my picture lately?
http://en.wikipedia.org/wiki/Karl_Rove ) and dealing with the dealer.
: Give this a read:
http://groups.google.com/group/alt.autos.toyota/browse_frm/thread/3c45146
: ec7516bd/d5fa405710a871e1?lnk=st&q=toyota+fuel+filter+replacement+surface
: +area&rnum=1&hl=en#d5fa405710a871e1
: > "Sean Elkins" <
[email protected]> wrote in message
: > news:
[email protected]
: > : In article <
[email protected]>,
: > : "Karl Rove" <
[email protected]> wrote:
: > : > Nonsense. If that's the case, why has it since been moved on newer
: > : > Toyotas?
: > : > I changed mine at 70,000 miles (actually firestone did it for me while
: > : > they
: > : > were aligning the vehicle). you should have seen the
: > : > crap that poured out of the old one. it only took them an hour to do,
: > : > which
: > : > was less time than I could manage, plus I admit: let
: > : > them deal with the hassle of changing it.
: > : > "Sean Elkins" <
: > : > news:
[email protected]
: > : > : In article <
[email protected]>,
: > : > : "Stephen Lascari" <
: > : > : > What involved in changing the fuel filter on a Tacoma 2002/4cylinder?
: > : > : > You
: > : > : > can not see the rear fuel line(from the fuel tank) connection since
: > : > : > it is
: > : > : > under the intake manifold. Does removing the starter motor help make
: > : > : > the
: > : > : > job
: > : > : > easier??
: > : > : If it isn't clogged, don't change it. They designed the thing with
: > : > : enough surface area to never need replacement. They made it hard to
: > : > : reach for a reason, or so I'm told.
: > : Check your manual--what's the recommended interval for changing the fuel
: > : filter? IIRC from my 97 Tacoma, there isn't one.
: > : I had mine changed at about 70K as well, but I think it was a waste of
: > : money.
: > : Google this newsgroup about fuel filter changes on Toyota--there was a
: > : thread a few years ago about Toyota intentionally making them hard to
: > : access so people wouldn't change them needlessly.
