2006 Tundra Stereo Harness
Searched first and didnt find exactly what I needed.
My buddy just bought an 06 Tundra with the standard audio (2 rear door speakers, 2 front door speakers and two tweeters) and purchased a new head unit for it. The Metra wiring kit he purchased matches the standard Toyota sound system harness, but in no way matches his. We thought it had the amp installed, but it is nowhere to be seen. I thought he OEM amp was located just beneath the head unit it the dash near the HVAC controls, but there is none there. I also followed the harness as far as I could without finiding anything. I can remove the lower console and look around, but thought I would check to see if anyone here knew where the amp would be located on the 06, or if they changed the standard wiring harness for the 06 before I go any further (hopefully to save a bit of time) I have no issue creating a harness for it, but hoped that either they just moved the amp or someone knows of a newer harness adaptor that will work. Thanks in advance for any help.
