Problem solved-Check Engine Light-Problem Solved!!
I have a 2000 Camry with a V6 and automatic transmission. I have about 38,000 miles on it. Recently, my check engine light came on. I did a search in the Camry Forum and found many threads. I got found some good advice about going to AutoZone so they could diagnose the problem for free. AutoZone told me my gas cap wasn't tightened enough at my last fill-up. The guy at AutoZone re-tightened my cap and re-set the ECU. The check engine light was gone. After a couple of days it came back on. I went back to AutoZone and they told me it was the cap again. We removed and then tightened the gas cap. The ECU was reset. Today I was driving to work and the light came on again. I have a feeling that if I go to AutoZone they will tell me that the scanner shows a code for a loose gas cap, again. Does anyone have any thoughts on what could be causing my problem? I could see having a loose gas cap once, but not three times.
