Double check the gap on the electrode armature to make sure it’s in spec.
A test you can perform is to pull the plug and attach it to the coil pack and lay it on the valve cover. Crank the engine over to see what color the spark is.
There’s a spring in the coil pack that stretches over time. Try swapping coil pack and plug to verify its moving to another cylinder.
