on the ST185 the diagnostics bridge Te1 and e1
then go to the cabin and turn key to ON
watch the flash of the engine managment light
blink-blink-blink - - - - - blink-blink-blink-blink
is error 34
this is a crude way of reading ECU error codes stored within
note them ALL as stuff like the map sensor, knock sensor, fuel, and even the temp gauge is monitored
then remove the 15 amp fuse from the engine bay ECU fuse box count to 20 then replace(same as taking earth off but keeps clock etc)
Check engine light procedure and codes
Article URL:
http://www.gtfour.com/default.asp?article=AAAALS
Description: The ECU detects malfunctions or abnormalities in the sensor network and lights a check engine warning light on the Instrument panel. At the same time the trouble is identified and a diagnostic code is recorded by the ECU.
Keywords: ecu warning check engine light error code34
Category: Repairs - Engine/ECU
Submitted: By dblack on 7/12/2000 8:38:07 PM, Updated on 7/16/2000 7:52:27 PM
T O Y O T A C E L I C A G T - F O U R S E R V E R
The ECU detects malfunctions or abnormalities in the sensor network and lights a check engine warning light on the Instrument panel. At the same time the trouble is identified and a diagnostic code is recorded by the ECU. The diagnostic code can read by the number of blinks of the check engine warning light when terminals T and E1 are bridged within the diagnostics port.
Instructions for checking the ëCheck engine warning lightí
1. Locate the diagnostics socket in the engine , found on the right hand side of engine.
2. Bridge terminals TE1 and E1 with a piece of wire.
3. The "Check engine warning lightí on the dashboard will start to flash with any stored error codes
4 The number and consistency of the flashed indicates the error code.
Example : Error 24 - Intake Air Temp. Sensor fault
FLASHÖFLASHÖÖÖÖ.Ö.FLASHÖFLASHÖ.FLASHÖ.FLASH
Each number is separated by a pause. Therefore if the light flashes twice then pauses, then flashed four times , the code 24 is produced. The code is continuously repeated, and there may be more than one error code stored.
Once the fault is diagnosed and cured, it is a good idea to erase the errors codes from the ECU by disconnecting the Battery Negative cable.
CHECK ENGINE WARNING LIGHT ERROR CODES
Code System Description
11 ECU (+B) Momentary interruption in power to ECU
12 RPM Signal No NE or G signal to ECU within 2 seconds after engine has been cranked
13 RPM Signal No NE signal to ECU when engine speed is above 1000 rpm
14 Ignition Signal No IGF signal to ECU 8-11 times in succession
21 Oxygen Sensor
Detection of oxygen sensor deterioration
Heater circuit Open or short in oxygen sensor heater
22 Water Temp Signal Open or short in water temp. sensor signal (THW)
24 Intake Air Temp. Sensor Open or short in intake air temp. sensor signal (THA)
25 Air-fuel Ratio Lean Malfunction Oxygen sensor outputs a lean signal continuously for several seconds during air-fuel ratio correction. Open or short in oxygen sensor (OX)
26 Air-fuel Ratio Rich Malfunction Oxygen sensor outputs a rich signal continuously for several seconds during air-fuel ratio correction
31 Air-Flow Meter Signal Open circuit in VC signal or short circuit between VS and E2 when idle contacts are closed
32 Air-Flow Meter Signal Open circuit in E2 or short circuit between VC and VS
34 Turbo charging Pressure Signal Fuel cut-off due to high turbocharging pressure
35 Turbo charging Pressure Sensor Signal Open or short in turbocharging sensor pressure signal (PIM)
41 Throttle Position Sensor Signal Open or short in throttle position sensor signal (VTA)
42 Vehicle Speed Sensor Signal No SPD signal for 8 seconds when engine speed is between 2,500rpm and 6,000rpm and coolant temperature is below 80C except when racing the engine
43 Starter Signal No STA signal to ECU until engine speed reaches 800rpm with vehicle not moving
51 Switch Signal No IDL signal or A/C signal to ECU, with check terminals TE1 and E1 shorted
52 Knock Sensor Signal Open or short in knock sensor signal
53 Knock Sensor Control Signal in ECU Knock control in ECU faulty
54 Intercooler (water/air) Intercooler pump problem
