1 - 4 of 4 Posts
1998 Camry
Short version - My check engine light went out, but the Torque app is still showing a "logged" fault code. I'm sure the bulb isn't burned out because the check engine light comes on when I turn on the ignition without starting the engine. Any thoughts on why the light isn't staying lit up?
Long version - I had a P0401 code for a long time (years). Finally got that code fixed by replacing the vacuum modulator. In the mean time, I picked up a P0446 code. I have replaced the gas cap. I have not gotten around to checking/replacing the airbox VSV, charcoal canister, and/or charcoal canister VSV. The other day, I was driving and noticed that my check engine light was off. I plugged in my OBDII bluetooth device and checked the codes with the Torque app. It was still showing the P0446 code as a "logged" fault, but nothing comes up under the "pending" or "historic" fault options. Any thoughts on why the check engine light isn't staying lit, even though I apparently still have a fault in the system?
Look in sig
Sometimes I've seen the CEL goes off because I believe that the system monitoring didn't find a fault during that time, but still marks it as 'fault'? I'm not 100%, I hope other can chime in.
I've had some 'not a major' things cause the random on/off of check engine lights, but at the same time I've had CEL that made the CEL stay on all the time as well too.
1986 Toyota Pickup
It maybe one of those temporary codes that disappears after it takes several days of driving before the right conditions are met to complete the monitor.
1998 Camry
Well, the check engine light has come back on. Haven't checked codes yet, but I'm assuming it's the same P0446. Still seems odd to me that it went off for a week.
1 - 4 of 4 Posts
