1 - 9 of 9 Posts
2007 Camry SE V6
Came across the following post at TOCAU.
http://au.toyotaownersclub.com/forums/index.php?showtopic=21209
The OP claims HP gains of 20-30. Your comments on this please.
If you are asking whether you can get 20-30 hp at the engine from a proper exhaust, intake, and removing the cats, the answer is yes. However, I don't think you would get more than 10-15hp at the wheels. You may also see a boost in gas mileage, though you may lose a little low end torque.
2GR FTW
2007 Toyota Camry SE
Pretty cool though, all that effort done to remove all the cats and resonators, practically running straight pipe from header back. Not sure how much gain you actually get by doing that, may lose some backpressure for sure though. Even with all the restrictions removed, there isn't enough of an exhaust airflow increase to compensate for the freer flowing air in the exhaust.
Would be helpful if he's running meth or nitrous though.
I'm not sure on the stock injector sizes, but it should be plenty for na applications, even if he does intake/headers and etc.
'07 XLE 4 cyl.
1 - 9 of 9 Posts
