1 - 3 of 3 Posts
Hey guys, I have a 1999, with the auto-climate control. I have heat/cold air, and all fan speeds work without any issues. The problem is, I can't redirect the airflow to the floorvents or windshield defrost vents, when the corresponding button is pressed on the panel. Usually I could hear a faint motor sound that probably moved an internal vent routing barrier as I would switch between the airflow settings. I'm sure someone else has had this issue and has a part number description. Any help appreciated, thanks.
Super Moderator
You might try searching on this over on the Gen3/4 Camry forum DIY sticky. Sometimes the motor's gone bad, sometimes the plastic actuator arms are broken. If you're hearing the motor running, yours is probably the latter.
1 - 3 of 3 Posts
