So far the problem was always caused by sway bar bushings going bad every 80k miles or so. But this time, that is at 230k miles, the clunking did not go away after replacing sway bar bushings. I cannot tell 100% if the sound comes from the front or rear.
Stats about suspension:
Balljoints are new.
Rear struts replaced some 12k miles ago, rubber mounts at the top looked OK, so I left them be.
Rear suspension arms bushings are old.
Rear sway bar links are new.
Front sway bar links are a bit dodgy I guess.
Front control arm bushings are old.
Front strut mounts are unknown condition.
I wonder where to start looking, what is most likely causing the clunking?
Sway bar links, rear/front suspension/control arm bushings or perhaps strut mounts? I suppose all of them could but which one is the most likely culprit?
Balljoints are new.
