1 - 9 of 9 Posts
i just put a new slave cylinder in because the old one was leaking. i bled all the air out of it and now my clutch grabs at the very top of the pedal, is there any way to adjust anything on a hydraulic clutch or do i have deeper problems than that? i figured it was grabbing high with the other cylinder because of air but now im not thinking that.
Soylent Green sales
rock crawler
There are 2 adjustments for the clutch, pedal height and freeplay.
The other thing is wear, how many miles are on it?
only 146xxx it doesnt slip or smell or anything like that its just an uncomfortable height that it grabs at
Basically you need to crawl under the drivers side floorboard and adjust the clutch pedal so that it moves about half a inch before resistance is felt.
Discussion Starter #6
so i adjusted the pedal so that it doesnt come up as high but i think i might just put a marlin 1600lb clutch in to be on the safe side
Discussion Starter #9
do you know what the stock clutch grabs at? i want better than stock but i dont need a top end clutch for my weekend wheeling adventures. i want a new one because i have a feeling my clutch is on its last leg
1 - 9 of 9 Posts
