1 - 3 of 3 Posts
Loud Street Machine!
i am having a problem in 1st and 2nd gear...in first gear it will jolt real bad, then a little less in 2nd, (like it's slipping) but it only seems to do it when its cold..once its been running for a while it wont do it...
Does somone wnow what it is or if i should get a new clutch???
Pics of my car here:http://www.cardomain.com/memberpage/692291
clutch
have you checked the clutch cylinder? check to see if your low on fluid and try bleeding the clutch, kinda seems like your clutch is semi engaged still, and doesn;t do it when ur warmed up because you have build pressure in the clutch lines so it's fully off. anyays thats my guess.
1 - 3 of 3 Posts
