Ok so I had a problem with my clutch having too much loosnes in the pedel and not disengaging entirly. So i figured it was the slave. I went to check it out and it looked as thoe it was severly leaking(had low fluid) so i changed out the slave. Now it's installed (a pain in the butt) i'm try to blead it and pedel to the floor every time. I try opening up the bleader after 15 or so pumps no air only a little fluid comes out. After several attempts the pedal is still to the floor no resistance. It's also not using up any of the fluid in the master cylinder. So could my master cylinder be gone?
