I think everyone agrees that the clutch feel is horrible on the new Tacomas. For me, the main problem is that the clutch doesn't start to engage the transmission until it's well off of the floor. You have to pass that "dead" area before you actually start to take off. In my opinion the truck should start to take off when the clutch is about a half inch off the the floor board.
I don't know the proper names for these parts so hopefully you guys will understand what I am talking about. The rod/piston that the clutch pedal pushes into the floor board has a plunger head that is screwed onto threads on the end of the rod/piston. I think if the head of that plunger were to be screwed farther down the rod/piston that would shorten the clutch throw the distance that the head is moved down on the clutch rod/piston that is pushed into the floor board by the clutch pedal. Does this make sense to anyone? How do I remove that rod/piston?
